Originally Posted by insite
i can't be sure without driving the car, but my gut tells me that the ring gear in your differential is damaged. a seasoned porsche mechanic should be able to drive it a hundred feet and tell you if that's the cause of the noise.
(i hope i am wrong!)
have you ever had the transmission fluid replaced? if it was filled incorrectly, this can happen.
no, but i just bought the car a month ago.
what makes you think it is the ring gear in the differential?
other than inspect cv joints (is there a way that depressing the clutch could remove cvj noise????), is there anything else i can / should do to inspect for the obvious?
what would a porsche vet be looking for when driving the car that would be indicative?
