Old 09-10-2010, 07:51 AM   #10
jwade
You have to remove the plastic ductwork to get at the switch. It's easy, just slide it out. The pain in the ass is getting your body upside down in there just right to remove it, but you do not have to remove a seat or anything to do this.
Just get a small step stool and place it by the door once you open it. I set a blanket over the stool to keep the stool from hitting the paint. By placing the stool, it allowed my body to stay at the angle of the door swing.
Get you a couple flashlights too. One small one for your hand and one larger one that can sit close to the accellerator pedal and angle up into the area where you will be working.
To remove the set screws for the ignition switch, you need a flat head micro screwdriver.
'13 S - Guards Red / Luxor Beige - Options - Loaded to the Hilt!!
'01 S - Guards Red / Beige - Surrendered - 04.18.12
jwade is offline   Reply With Quote
