Old 09-08-2010, 07:27 AM   #12
ppbon
ppbon's Avatar
About $3,000...
Originally Posted by DerrickCaracter
on repairs only (not customization)
... because I decided to check my IMS bearing.
That led to replacing the bearing with an LNE Retrofit, the RMS, the Clutch, and the Flywheel.
I had also replaced the Brake Master Cylinder and the Clutch Slave Cylinder.
But I need to point out that my car was at 197,000 miles at that point.
Now I should be good to go and will only need to replace minor worn suspension components.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
