Update: Oil cooler was replaced and coolant was flushed, but I was told that they were not able to get all the oil out and I would see residual oil for awhile. I was told to drive it and it should become obvious if it was only the oil cooler that was the problem or if I have a bigger problem as well. I have driven 500 miles since the oil cooler replacement and flush and the car is running 15 degrees cooler than before land everything seems great. I do still see residual (hopefully) oil in the coolant tank and I dip a paper towel in the tank and soak it out. The amount of oil is a small fraction of what it was before. When I look in the tank I can see the chamber next to the main chamber always has more oil in it. Is there a way I can clean out the entire coolant tank and not just the main chamber? Thanks.
