I thought it was available in the q7 now. If not then the 3.0 v6 diesel is. it weighs only 425 lbs, 11 lbs lighter than a 3.2 boxter s motor and has 240hp and 406lb-ft of torque from 1700-2500 rpm. and is quite compact at only 17 inches long. it may be taller though, due to having the turbo mounted in the vee.
