battery tender
you may want to consider buying and hooking up a battery tender during the periods when you are not driving it.
secondly as previously indicated, there are a number of systems that remain active if you leave the key in the ignition. IIRC there was some info suggesting that its best to remove the key and lock the doors, thus allowing the systems to sleep, and reducing the battery drain.
claus
03-r1100s, 11-f800st, 09-987.2, Norton Commando
auf adlers fluegeln getragen
