Old 09-01-2010, 11:05 AM   #3
jhandy
I have had the same issue for 3+ years. I have tried all sorts of wheels, rotated balanced and changed tires, replaced disk rotors, bearings..... the list goes on.
the only this left is to check or replace control arms or bushings. I cant imagine that after replaceing eveything that rotates this problem will not go away.
one thing I have noticed, that the shaking comes and goes, at speeds over 50mph. I cant see where a tire or rim can be out of balance one day then back in , and back out. When it happens it is a rythmic situation depending on speed. At 75mph, it shakes hard for 7 sec, smooth for 4 sec, and shakes hard again for 7.
way too weird.
This has stumped all that has tried to fix it. Anyone have suggestions for us?
2002 S
jhandy is offline   Reply With Quote
