				Thermostat replacement
			I'm replacing my thermostat with the LN Engineering one.
My questions: Would clamping the hoses to the thermostat housing and to the water pump (or any other ones) limit the amount of coolant that will drain when the thermostat housing is removed? Would this reduce the amount of air getting in to the system  that will need to bled out?
Regards,
mike
