OK... UPDATE and some new goodies.
All prices do not incl. S/H, but are negotiable. PM me with any interest or inquiries.
NEW ADDITIONS:
2 NIB Genuine Porsche Brake Pad Wear Sensors 996.612.365.00
$25
2 Genuine Porsche Center Windstop Latches 986.561.737.00 (01) 01C
If your clear center windstop panel is rattling, the platic latches may be worn. Replace with these NIB latches and problem solved.
$8
4 NIB Genuine Porsche plastic rivets for attaching inner fender liner 999.507.497.40
Replace broken or missing rivets
$4
NIB Genuine Porsche Convertible Top Drive Cable 986.561.717.02
Replace your worn or stretched convertible top cable. The outer sheaths have a tendency to shrink from heat cycling and this can cause the cable to disengage from the motor or transmission. Complete repair req. 2 pieces, just one offered here, but at a savings.
$25
NIB Genuine Porsche Light w/ bulb for Footwell Light mod 997.632.201.00
Add the passenger side footwell light that Porsche left out. Easy mod - cut out P-side center console for the light w/ exacto knife and run wiring to the overhead cabin light behind the A pillar and header trim.
$5
_________________________________________________
Genuine Porsche Tequipment Savannah Beige Floormats, LHD, NIB
PN# 000.040.800.53.S30 incl. Hook & Loop fasteners which 'screw' into the carpet to secure the mats. Lloyds mats are good... these are better, and Genuine Porsche. Absolutely new, never installed, still in orig. Tequipment box. Give your Boxster a nice refreshed look.
$100
Manta Sport Racing 'Ernie' Bar NIB
Bought this and found it will only work on Manual cars (I had a TipS) - never installed. Very precision parts.
$100 - SOLD
Brake Master Cylinder, NIB
If your car is older, it may be time to replace the Brake Master Cylinder, or just keep it as a spare - it'll always fail on a Sunday when you have to use the car, this is a must shelf item for the older cars.
$90 - SOLD
Bosche Fuel Filter - NIB
$35
Two used sets of original 986 Tailights - 1 set under 6k mi.
Excellent condition, replace your old scratched lights and refresh your car's look!
$65/set
Brey-Krause Fire Extinguisher Mount - VG - Used
Will accept any 2.5lb. Fire Extinguisher w/ bracket. Allows full motion of passenger seat - non-obstructive. Req'd for some sport/track events. VG condition, slight chipping of Krinkle finish at the bolt holes - hidden - not visible at all.
$75 - SOLD
Module Master Porsche Boxster Climate Control LCD Repair Kit NIB
Replacement LED panel for Climate Control. Fix that 'Sunset Syndrome' from too much sun exposure. No soldering, wiring req'd.
$45 - SOLD
Pair of Black OEM Bumperettes - Used
Used set of rubber bumperettes. Slight scratch on one, otherwise perfect. Perfect for painting to match body color while saving yours to return to stock look. Or use as is to replace worn scratched or marred ones you have now.
$45- SOLD
Custom Front License Plate Holder - New, never used
Screws into Tow Hook recepticle - easily remove when you want - no need to punch holes into Bumper Cover
$35- SOLD
Used (6k mi.) stock front sway bar
$25
Coolant Reservoir - Used, but not cracked or leaking
Came from a 12k mi. car. Much cheaper than buying new.
$45 - SOLD
All prices negotiable. PM me to make an offer or get details.
Cheers!
