Old 08-22-2010, 12:03 PM   #2
HB.
Thanks a lot! You were right about the belt. I'm in the process of removing the old belt now. I've run into a bit of a speed bump, about 1 1/2 of the belt is wrapped behind one of the pulleys, and I'm having problems getting it off. I think if I can get a small sharp knife I should be able to cut it loose.
HB. is offline   Reply With Quote
