What's the most smoke you've seen from the exhaust at start up?
Once in a while I see a small puff of smoke at start up. I understand this is normal. However, today, at the track, I started the car and a LOT of smoke poured from the exhaust. So much so, that a couple people came running with fire extinguishers. It lasted a couple minutes, so I shut it down and let it sit. An hour later, I fired it up again and more smoke came out, but maybe just half as much. Still, it was what I would consider a lot, and I decided not to go on track for fear of something being wrong and dropping oil on the track. I let it sit another hour, fired it up and a little bit came out as I drove through the paddock to the highway. I drove the car 30 minutes, shut it down and went inside for a burger. When I came out I checked the oil, which was at the maximum mark, just like yesterday. I started the car, and there was zero smoke. I drove home, let the car sit a little bit, and the oil is still at the max mark.
Based on all of this, it seems to me like I just had oil settling in the cylinders. But it seems like there was a LOT of oil in the cylinders. Has anyone else experienced this? The car has a perfect maintenance record and has not given me any problems in my four short months of ownership.
FWIW, after my last session on the track I shut the car off without letting it cool down first. Not sure if that had anything to do with it, though.
Any thoughts?
"Of all the extreme sports I've ever participated in- windsurfing, kite boarding, wake boarding, tow-in surfing and snowboarding- skiing, for me, made everything else easy."
-Chuck Patterson
