Old 08-21-2010, 02:33 PM   #6
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
What I'm trying to do is explain to you that when your belt breaks you can drive the car, but if you do, you will overheat the car since the water pump will not be running anymore, as well as the power steering being lost because that pump is also run off the belt. Do not drive the car until you replace the belt!!!!! Also, your battery will eventually die because the alternator which recharges the battery will not run without the belt.
