Thread: car won't lock!
Old 08-19-2010, 08:06 PM   #28
sb01box
Originally Posted by 97 Boxster
Will I damage the DLM by adding heat to the part where the solder needs to be repaired? How careful should I be? Any risks in taking the DLM apart?
Reflowing solder is normal soldering operation. Simple if you know how to solder.
Taking the unit apart is relatively easy . I did not take detail photo to show you.
I recall that a plastic plate had to be remove first then removal of one halh of the case. Once there, the pwb solder joint can be examined. If it looks like the photo I placed in previous response to this thread, then the problem is there.
Reassembly is little bit tricky in that there are couple of alignments of cam/plunger or the mechanical "action" will not work.
We've two threads going here... Your three DLM's, were they new? If so, cold solder joint does not seem likely.
sb01box is offline   Reply With Quote
