Old 08-18-2010, 12:23 PM   #3
chaudanova
George, I've got the IPD Plenum.
What you'll need is a modified 3.4L Cayman plenum. The nipple is modded (larger) for the 986 boxster, and one other portion is also slightly modded.
Mate that 75mm 996/987/997 throttle body to the cayman plenum, and you'll also need two reducer silicone hoses and clamps for the plenum to connect to the manifolds.
From there, you'll also need either your own custom piping/hose, two IPD cayman hoses mated by a pipe, or the new IPD boxster hose (one piece proper fitment).
I'll have some updated pictures soon, as I'm one of the first with the new one piece silicone IPD hose for the 986.
Here is a picture of the current/temporary setup.
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
