As it is, no- the 99 muffler mounts differently from the top than for the 2000-2004 Boxsters. The only difference is that your car has a muffler that has two threaded studs that point straight up that fits into a mounting bar with two vibration damping cylinders. The pre-2000 mufflers have two threaded bolts that point straight back towards the front of your car, and mounts directly into a tranny mount.
You can, however, fabricate a mount to make it work with your car. Perhaps a local muffler shop can do this for you. Or, maybe you can adapt it to your current muffler mount to make it fit.
