do it yourself. it's not hard. check this site for instructions. i replaced switches on mine and my wife's box. only takes 20-30 minutes. i suggest purchasing a small jewelers screwdriver for removing the ignition switch. you can buy the switch online for less than $20.
you might want to do some research on water pump and aos...those will fail eventually. water pump should go around 60k miles. aos varies, but if you catch it early you will save hundreds in o2 sensors.
good luck!
