Thread: car won't lock!
Old 08-15-2010, 09:08 AM   #27
sb01box
Originally Posted by 97 Boxster
I see what you are saying. Problem is, I have tried two of these door lock mechanisms and both are doing the same thing. I cant help but think its something in the harness itself somewhere. Today when I went out it worked just perfect. Its almost as if when i go down the road and it shakes something in the harness and then the lock button on the dash lights up automatically and then the windows stop dropping as they should and my alarm doesnt work like it should. Its like a trifecta of issues once I am out on the road. I still cant explain why it was working perfectly today and that yesterday it started acting up again. Has to be a wiring issue somewhere. Dont think the DLM is bad since I have tried 2 different ones.
I was keying-off of your earlier thread where you reinstalled the old unit and it worked.
Next time when you have the door panel off, with battery connected wiggle the harness near the connector. This is what I inadvertently did when trying to disconnect the harness from the DLM. The window and the interior light started to "respond"
sb01box is offline   Reply With Quote
