Old 08-14-2010, 04:10 PM   #6
JFP in PA
You have an intermix problem; common causes are a failing oil cooler (common), a popped freeze plug (also common), blown head gasket (less common), or a cracked head (also less common).
You need to stop using the car immedeately. It needs to be checked by someone that knows what they are doing. If it has to be moved to get it to them, flatbed it, DO NOT DRIVE IT.
