Old 08-14-2010, 01:42 PM   #20
litlchi
Successfully fixed window but...
So my window on the driver side of my 2003 Boxster S was also not going down enough when I tried to open the door so I tried the zip tie method below and it worked like a charm. I used the exact same setup as shown in the picture with two on the cable close to the spring and one on the lower green portion of the cable. However, after I finished and reassembled everything, now my airbag light is on. I'm assuming it's my side airbag and I swear I reconnected the one connector prior to reinstalling the panel. Does anybody else have an idea what might be going on? I did disconnect the battery during the disassembly of the door, reconnected it when I had one the window motor and regulator in view, and then disconnected it again when I reassembled the door. If nobody is sure, I'll likely break down the door again to check the connection but wanted to see if there might be another reason...
litlchi is offline   Reply With Quote
