Thread: car won't lock!
Old 08-14-2010, 11:56 AM   #26
sb01box
Originally Posted by 97 Boxster
So you took the DLM apart?? Where did you add the solder too?
first picture shows the pwb (green)and the connector (black to the right) where the harness is attached.
the second photo shows the pin coming out of the connector and soldered to the printed wiring board.
if you see this type of wave in the solder, it is bad.
sb01box is offline   Reply With Quote
