Thread: car won't lock!
Old 08-14-2010, 07:54 AM   #42
sb01box
Originally Posted by 97 Boxster
Well, I shouldnt have jinxed myself. My door locks/window drop worked last night and this morning on the way to work. Even once I got to work the door window drop and locks worked as they should.
After work I went to get into the car and it wouldnt unlock both doors. The key in the lock just turned without resistance and when I opened the door the alarm went crazy. The window did not drop either.
This is too crazy. Has to be a short or bad connection somewhere is all i can figure. Can anybody shed any light on this?? Before you comment read my earlier post today to see what I already have done.
I want to tackle this tomorrow morning so any response is appreciated.
next time when you have the panel off, wiggle the connector body of the harness attached to the DLM. my car exhibited erratic window/interior light and window movement when the connection was wiggled.
I found bad solder joint in the printed wiring board inside the DLM.
reflowing the solder joint fixed problem.
sb01box is offline   Reply With Quote
