Disconecting the car battery will not help as it has an internal alarm battery,
I have had similar problems with my 99 2.5 mainly in warm weather(so not often!)
For a quick fix while you are away try double clicking the key fob when you lock it the alarm should chirp to show that the internal sensor is not activated this might stop the alarm going off untill it can be checked out.
