Old 08-10-2010, 03:14 AM   #3
eightsandaces
Well, easy breezy to plug and play, but a bit more work to dial in the correct lighting height. The factory recommends having someone sit in the drivers seat for weight during adjustment, then you use the oval access ports to make corrections. There is also a specific distance from overhead door target but I forgot what that is.
eightsandaces is offline   Reply With Quote
