Thread: Alternator
Old 08-08-2010, 09:21 PM   #3
mikehkang
Smell
Originally Posted by mikefocke
an alternator not produce its top "juice" till 2-3k RPM? I recall the testing is not done at idle. And I recall jump starting others cars, the best results were after reving the donor car's alternator to 3k for a bit.
Is the Subi's voltage regulator part of the alternator or separate?
Connections clean and secure?
Thanks for your interest Mike.
Well, I am thinking my alternator is bad because,
1. There is this burning smell when I open the hood.
2. According to my gadget, the alternator is producing a little bit more than 12v at idle. And the gadget says this is not good. (My 3 others cars pass the gadget test at idle.)
3. The car runs fine when I am driving at 2-3k RPM, but starts to idle rough and dies when parked in the driveway. (This after the Subi was jumped using a portable jumper and driven for about 15 mins. with high RPM.)
It is entirely possible that Subi needs more love, I mean driving time.
The combination of short distance local driving, less than 8 miles each way, and infrequent use, once a week, is not charging the battery enough.
I have fully charged the battery using a trickle charger, however, the burnt smell near the alternator leads me to believe the alternator is cooked.
As for the location of the voltage regulator, I need to research.
The battery is new. Got it from Costco back in Feb.
It is the burnt smell that bothers me the most.
What do you guys think?
mikehkang is offline   Reply With Quote
