You do not need to remove the ball joint to adjust toe. THere is a jame nut and then some flats on a threaded rod. Turn the rod to adjust toe and tighten the nut. If you do ont know what you are doing and how to measure it you may end up with a car that is difficult to drive and wears tires very quickly.
Chris
