Guess I didn't read the original post well.
your car may have similar problem that mine had, bad solder joints between the connector and the printed wiring board in the door mechanism. Hopefully it's not your harness bundle.
when you get into the door and determine that it is the door mechanism, see if there's a bad solder joint - it may only need re soldering.
Bad solder joint photo is from my car.
