Old 08-03-2010, 11:41 AM   #2
favino1006
There are two arms with a single, center bolt, one on either side of the car, just below the base or hinge of the clamshell that will allow the top to slide forward more. The attached photo is of the driver side. I want to say it's a 10mm or 11mm socket...
Open your top 4 or 5 inches away from front window edge then stop. Run around back and loosen the bolts one at a time and slide the top forward gently a little bit on each side then, retighten the bolts. Get back in the car and close the top to check the fit. You may have to adjust a couple of times before you get the best fit.
Hope this helps =)
-ian
favino1006 is offline   Reply With Quote
