Thread: car won't lock!
Old 08-03-2010, 07:43 AM   #16
RandallNeighbour
I've no idea what all those codes mean nor did I hook up my boxster to an ODB tool.
What you are describing though is a bad door lock mechanism in the passenger side just as I had. When it could not lock the door, it sprang back into unlocked mode.
You are in luck though. The 98's through the 03's use the same part number and you should be able to get a passenger door lock assembly cheap and they will be plentiful.
You can take off the door panel and pop it out in under two hours if you are willing to give it a try. The only difficult part is finding the correct bit for the bolts on the exterior of the door that hold the mechanism in place. I bought a rather expensive 12-point bit set from Sears to do the job and it still didn't break the seal on the bolts they were so tight and I ended up stripping out one or two of them. Vice grips on the edge of the bolt does work though but you'll need touch-up paint afterwards if you are as anal as I am about my car.
Start contacting salvage yards.
