Old 07-29-2010, 12:08 PM   #5
Jaak
Jaak's Avatar
Unit is easy to "pop" out.
5mm Allen key required.
Remove the drivers side (UK side) covering in the front trunk.
There is a rubber piece that sticks out in the middle, pull it out.
Insert 5 mm Allen key into the opening and rotate the key 180 degress to the front of the car. Key starts with the handle facing the rear of the car. The headlight pod will move forward. Rotate the key 90 degrees to the rear.
Slide the pod out and flip it over. You will see where the access to the bulb is and pop uff the rubber gromett. Replace the bulb and reinstall the pod the same way you popped it out. You only have to move the allen key 90 degrees to the rear when installing the "pod". make sure it is locked in.
2002 Boxster S Seal Grey
2010 Ford F150 FX4 Luxury
Retired after 38 years with the same company.
Jaak is offline   Reply With Quote
