Old 07-27-2010, 05:34 AM   #4
blue2000s
Porscheectomy
Have you done an inspection and bounce test? If they're not leaking or bouncing you might want to just try an alignment first and see if that does the trick. A good alignment shop should be able to tell you if any of the suspension links are damaged while they are under the car. Ask them to do it.
That is, unless you want to replace your struts. Because some people like to do it as an upgrade. Usually they will replace springs and maybe sway bars at the same time. Replacing just the struts doesn't make a huge difference in the car's handling (unless they are worn out). 43000 miles isn't a lot for a set of gently driven struts. But as always, your mileage may vary.
