Old 07-26-2010, 07:12 PM   #5
Johnny Danger
Johnny Danger's Avatar
The only time that you might run into clearance problems is if you switch to adjustable coilovers. In the past, I had some clearance problems with a set of 8.5 +50 wheels that I used in conjunction with a PSS9 set-up. Essentially, the wheel would not clear the adjustment ring on the perch unless I used spacers. Not that using spacers was a concern, however, there are some enthusiasts who prefer not using them . Had that been the case, because of the offset, a wheel of that dimension would not have fit.
