Old 07-08-2005, 06:51 PM   #1
Pablito
Tire pressure is usually checked on cold tires, mfg recommendantions already factor in the heat build-up difference....However the best indicator is tire wear, middle wear indicates over-inflation, wear on the edges indicates the opposite....Here's a good idea, Costco had introduced Nitrogen mixed air for the tires they sell. The gas helps stabilize the temp inside the tire and aid in a more consistent wear and air pressure, for me it was great news since here in the tropics we have pavement at around 100+ degrees almost all year round....
Pablito is offline   Reply With Quote
