Old 07-25-2010, 02:13 PM   #27
BYprodriver
BYprodriver's Avatar
Originally Posted by BYprodriver
Has your car ever run Hot? (240+) When my 2000 S AOS failed I replaced it & it still smoked slightly, cleaned thin film of Mobil 1 from Throttle Body & intake tube & cured smoking. Later removed Intake Manifold & saw simular amount of oil inside but no smoking. Removed sec. Cats & no sign of oil there. I would think if you had oil in cats it would light the check engine light with codes. Has your car ever run Hot?
SO... does it only smoke when the temp gets to a certain level ?
