Old 07-25-2010, 01:49 PM   #16
Viper5
I believe the root problem is that over time, the cable will stretch, thus the regulator does not pull the same distance as it should even though it is doing the same amount of rotation. By placing zipties or other spacer applications in spots which pull the cable, you can tighten the cable up and thus the distance is the same as it was originally.
Viper5 is offline   Reply With Quote
