roof won't close...my 2000 S has the same problem!
I believe my problem is with the latch microswitch at the top center of the windshield. I conclude this because the problem is intermitent and the windows fail to lower whenever the top fails to move. So now I want to reflow the solder on the microswitch. My problem is I can't get the microswitch wire connector to disengage from the recepticle! So I've got the latch assembly dangling from the windshield. This makes it difficult to solder.
What's the secret to removing the microswitch wire harness? Looks like there's a tiny hole with a tab in it. I've tried pressing a small metal piece in to depress the tab, but no luck getting the harness out.
Any ideas?
Thanks much.
