Old 07-24-2010, 08:02 PM   #12
husker boxster
husker boxster's Avatar
Originally Posted by dirkdiggler
also..... assuming the rear main-seal leak is the cause of the decent size oil leak.......... can i just check the oil very often and add as needed untill I get it fixed?? asking becasue I dont want the motor to blow on the drive home with it or something. Pretty much what can occur if the rear main-seal is leaking besides a little oil drippage?
Yes, many just keep an eye on the oil level when RMS first appears as a little drip. If the issue is more than just a drip (which it sounds like this one is), be aware that you're dumping $5-$6 a quart oil into your engine / onto the ground. You don't want to do this for very long from an expense stand-point.
1989 928 S4 5 spd - black
