Old 07-08-2005, 04:32 PM   #2
bigislandboxster
I BELIEVE you check your tire pressure when the tires are cold.....That is before you drive or just after driving. Can't say what temp is ideal, it always stays between 55- 85 where I'm at.....
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
