Old 07-23-2010, 02:02 AM   #1
JTP
This may seem like a good deal but from the description it sounds like it's in rough shape and likely will turn into a money pit, quickly. What kind of maintenance has been documented? Oil leaks in the areas you described are not good signs. And the rest of the car doesn't sound like it was owned by an enthusiast. By the time you do the clutch, RMS, IMSR, tires, brakes, control module, and top you're propably close to an additional 4k into the car. Save on labor if you do most of it yourself. Not having seen the car in person, I would not recommend this car. Better to apply that 4k to a better maintained vehicle. But if you're confident you can tackle all the potential problems have fun with it and learn.
If you had the resources to turn this into a track car or buy a Jake Raby built engine, I'd say negotiate the price some more and get it.
JTP is offline   Reply With Quote
