Thanks for the reply
But if I can get the car for $4400...... would that be a good enough deal to offset the leaks and other issues? I have a buddy that runs his own shop that should be able to do the RMS, IMS and clutch I assume ..... or do most shops not have the proper tools to work on Porsche??
I assume the oil leak is the rear main seal ..... sorta like oil is everywhere..... or could it be a leaky or loose oil hose?? If it was a RMS wouldnt the oil just sorta seep downward and not be everywhere?
the issues with the top dont bother me all that much, I have no problem getting out of the car and lifting the top up and down manually.
Pic attached of the leakage
