Old 07-22-2010, 11:33 AM   #26
Wret
Any time JTP. Let me know if you want to take it for a spin. By the way, here's a parts list if anyone wants to put one of these together.
Hushpower DBX mufflers 2” inlet/outlet (2). Special Order by phone from Flowmaster. At the time I ordered, 2” ID was the smallest diameter available. This requires shims to get down to the 1 Ύ inlet pipe. Call 877-394-2878 ext 716 for more info.
3” Stainless tips, 2” inlet. Max 6” length. A 6” tip will protrude about an inch more than the stock tips, which to me was not an issue. If you want to keep the tips tucked as far under as stock, you will need to find a shorter tip. I bought these from Summit but you may be able to get them direct from Flowmaster.
http://www.summitracing.com/parts/FLO-15360/
2” 90° bends with 2” radius (2) Don’t get a larger radius or they won’t fit.
http://cgi.ebay.com/ebaymotors/2-mandrel-90-degree-bend-304-stainless-/270600943010?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item3f0112b5a2
2” 90° bend with longer legs. The bends above have very short legs with very little excess material. Some 2” straight pipe is necessary for shim stock (only really need about 6”). This one comes from Jegs and may get you a free hat. 
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=200474206900&ssPageName=STRK:MEWAX:IT
Stainless steel bar stock 1” x 1/8” x 36” (min)
http://cgi.ebay.com/1-8-x-1-Stainless-Steel-304-304L-Flat-Strip-Bar-48-/180360116257?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=%257B%2522Page%2522%253A%2522%252FMetals-Alloys-%252F29402%252Fi.html%253F_nkw%253Dstainless%25252 01%252522%2526_trkparms%253D65%2525253A12%2525257C 66%2525253A2%2525257C39%2525253A3%2525257C72%25252 53A3018%2526_trksid%253Dp3286.c0.m14.l1513%2526_pg n%253D3%2526hash%253Ditem29fe4cf821%2522%257D
2.25” muffler clamps (2) preferably stainless steel
http://www.summitracing.com/parts/SUM-694722/
Replacement bolts and nuts for clamps between the cats and mufflers (2) preferably stainless steel. M8 x 50mm (or longer). The bolts will likely be unusable after removal and may need to be cut.
M8 x 30mm (or longer) stainless bolts for hangers (2).
Wret is offline   Reply With Quote
