Originally Posted by gwoodburn
http://www.lnengineering.com/ims.html
The prices are at the bottom of the page.
$895 = Upgrade
$519-$595 = Retrofit
If its labor your talking about, then the Retrofit should cost you an additional 2-3 hours on top of a clutch job. Depending on what the hourly rate is in your area I would say maybe an additional $200-$300. If it is a double row bearing, it may take a bit longer because they can be harder to remove. The Upgrade requires the engine be completely disassembled so I don't really know a dollar amount. You probably do not want to go that route unless you have another reason to disassemble the engine.
Thanks, but I'm trying to ask Jake what HIS flat rate is for the upgrade (if he has one).
2002 Boxster S, 6 speed, Speed Yellow
Flat Six Innovations 3.8L Stage II Track Performer, RoW M030 Suspension, B&M Short Shift Kit, Fabspeed Bypass Pipes, FVD Brombacher "Sound Version" Muffler, UD Pulley, Low Temp T-Stat.
