Thumbs up the AOS installed...it needs to right on or your problem will not go away. The J-tube on top is usually replaced at the same time. Also the lower tube can fail and crack or suck air around the orings. I would check the AOS to be sure it is in correct. There is a place it goes into the block and the notorious boot...usually this is where you might get a problem.
Old Hippie Young Heart
