Originally Posted by BYprodriver
1997-1999 has a smaller pipe diameter & flange 3 bolt pattern so they will not bolt together. If you are refering to 2000- 2.7 pipes I am not sure but I bet if it is same gasket part # it probably is the same.
Yes, I am referring to the 2.7 engine. I know that the 2.5 has a completely different exhaust configuration. Thanks for pointing that out .
