I have a set of secondary cats for sale that came off of my 986 "S". I have received several inquires from other boxster owners regarding compatibility with their base model . Clearly, the headers/pre cats are completely different between the "S" and "non S". However, are the secondary cats different between the two models ? Will they work with either engine ? Does anyone know ?
1997-1999 has a smaller pipe diameter & flange 3 bolt pattern so they will not bolt together. If you are refering to 2000- 2.7 pipes I am not sure but I bet if it is same gasket part # it probably is the same.
