Old 07-15-2010, 05:49 AM   #25
97 Boxster
97 Boxster's Avatar
Originally Posted by MN 986
I had this problem last year. As others have said, you definitely need to replace the door lock assembly. The problem is a microswitch inside the latch assembly, but you can't get the switch by itself. I tried lubricating it with no luck and then replaced the door lock assembly. It was a DIY for me.
The part is called the 'Door Lock Mechanism', and is available at: http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=986M&section=INTpnl&page=1&bookmark=4&part_number=8N1-837-015-C-M100
I got mine at the local dealer for a few $ more, but it was worth it to get it done the same day.
You will need a special type of wrench called '12 point triple square' to remove the part from your door, but I found a set at the local O'Reilly Auto for not much $. It is used to remove the 2 bolts visible on the door jamb part of the door.
Good luck with the repair!
Thanks for the information. I will order the part and get right on it. I was just going to ask about the tools needed.
On top of this my ignition switch seems to be going out on me. Car electronics turn on but the ignition takes a few turns back and forth to make the car start. Ugh
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
97 Boxster is offline   Reply With Quote
