Old 07-10-2010, 12:37 AM   #2
gschotland
O2 sensors are very easy to change with the right tools. You can use a closed end wrench (spanner), but the job will be easier with a specialized oxygen sensor tool (see photo attachment below) and they're cheap, around $10 here. Use a long ratchet with this because you'll need some leverage to loosen the sensor. Spraying the sensor with WD40 or something similar on the threads first is helpful.
It's generally recommended that all 4 sensors be replaced at once. Your car will run significantly better. You may be able to get by doing one, but you're postponing the inevitable. You'll save time and money by doing all 4 at once.
There are many cheap "universal" O2 sensors that can be made to work, but IMO it's not worth the trouble or taking the chance. Spend a little more and get the ones with the OEM type connectors, then you'll have no worries. This Porsche specialist had the best prices for the OEM type when I bought 6 months ago. They may be cheap enough to justify posting them to the UK.
http://www.maxspeed-motorsports.com/15182.html
Search the site for MANY threads about O2 sensors and related CEL (check engine light) codes.
Also, invest in a Bentley shop manual. You'll get a lot of use out of it.
http://www.amazon.com/Porsche-Boxster-Service-Manual-1997-2004/dp/0837613337
Let us know how you make out.
gschotland is offline   Reply With Quote
