Old 07-09-2010, 09:08 AM   #1
Boxsterund914
Originally Posted by kabel
if your serious about it, maybe it is time for a set of front adjustable camber plates
Or go with the adjustable GT3 lower control arms. You can adjust the camber all the way positive at the top and set the camber to what you want with the shims in the control arms. That's what I did. It gives you a very slightly wider track in the front and allows whatever camber you want to have.
Boxsterund914 is offline   Reply With Quote
