Old 07-08-2010, 10:29 AM   #1
mikefocke
Have you an owner's manual?
Headlight bulb replacement is covered there. Only tricky thing is the high beam is the lower bulb, low beam is the higher one. You can test the bulb theory by swapping the high beam and low beam bulbs in the standard headlights (non-Litronics).
If you don't have an owner's manual, PM me. I can point you to an electronic copy.
