Your AC evaporator drains are clogged. Not unusual, not a big deal.
You need to raise the car and locate the drains. Push a length of coathanger wire gently into the drain. Do not lie directly underneath the drain because a small torrent of water will likely gush out.
If nothing happens, the drain tube may have come dislodged in which case you'll need to look for it under the dash and re-attach it. This is rare and it's most likely just a clogged drain.
Cheers!
