Thread: battery arcing
Old 07-04-2010, 11:05 AM   #3
mikefocke
Are you sure the terminals are
the same as the ones on the battery you removed. IIRC, the ground/negative is on the right side as you face the windshield from the front of the car. There are batteries where this is reversed. I'll assume you have the key out of the ignition switch.
